Two pipe system acting up
BrianF
Member Posts: 29
Not working right
What valves do the radiators have? Usually the valves were designed to meter the steam on vapor systems.
Steam in the returns will block the air from venting from other radiators.
Is the boiler running a vaporstat on a few ounces of pressure?
Orifice plates require no maintenance once you get them set up, steam traps need to be maintained.
What is in the near boiler piping? Anything unidentifiable?
Check valves were common on the returns from various vapor system return devices.0 -
Someone well versed in steam would have to go over this system and come up with a comprehensive plan to retro-fit it into submission.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes2 -
@BrianF
Post your location or check "find a contractor" on this site. Sounds like you have a mess on your hands0 -
Send the customer a link to this thread. Sounds like they are working with a snake oil salesman and about to get screwed out of a lot of their money.0
- 128 Chimneys & Flues
