Which manifolds work with Vevor 1/2" pex al pex?
Hello my radiant floor gurus. I have Vevor 1/2" pex al pex tubing. My prospective contractor asked me to find out if it requires a special manifold or will work with any standard manifold like a BlueFin or HydroSmart. Thanks in advance for your response. Paul
    hot_rod Posts: 28,544
    Does the tubing have an ASTM F1281 listing on it?
    Caleffi manifolds are available with PAP connectors.
    I have attached both to show the difference
    The PAP nut has longer insert, double end o-rings and the brass ferrule to grip the tube better
  • GroundUp
    GroundUp Posts: 2,572
    Hydro Smart doesn't make manifolds. but anything with a PAP fitting will work
  • TAG
    TAG Posts: 807
    The manifold is not the issue ...... you need to order the the correct fitting for the manafold for the PEX you are using. The PAP have o rings .... typically two.
  • Brando
    Brando Posts: 11
    Thank you all! I appreciate the feedback.
