How to plumb a hot water cast iron home radiator?
eclecticmn
Member Posts: 129
I am installing some hot water cast iron radiators in my house. I plan to put the inlet valve low on one side and outlet up high on the opposite side. Is that OK? Some in my house have the inlet valve low on one side and the outlet low on the opposite side. Some have inlet valve low on one side and outlet high on the same side.
Does it matter which side the bleeder valve is on and why?
update. Here are photos
Radiator one below
https://imgur.com/8eL0uRH
Radiator two below
https://imgur.com/axR8mLT
Radiator three below
https://imgur.com/7FopZMF
Radiator one below
Radiator two below
Home owner near Minneapolis with cast iron radiators, one non working slant fin now ripped out, and hot water heat.
