Steam pipe insulation using tape
I’ve read how effective fiberglass insulation is for steam pipe insulation. But is it possible to use any of the tape-type insulation? My basement is a finished space and I’d like to avoid the bulk and appearance of the fiberglass. And the paper covering is sure to get damaged. I’ve seen foil and other types of self-adhesive tape insulation in rolls, most with an R value of only 1 or 2. But it is less bulky and I think I can paint it after installation. Is there a specific type that I can try and is it worth it?
    EBEBRATT-Ed Member Posts: 20,485
    edited December 2022
    Anything else you put on is going to look like crap. We usually use 1" wall on steam but if the basement is finished and you want some heat off the pipes use 1/2" wall....less bulk. And you can paint the fiberglass
    Robbbbb
  • Waher
    Waher Member Posts: 373
    You could use Zeston PVC jackets over the insulation. Turns the entire run of pipes into a well protected smooth non-porous surface.
    https://www.buyinsulationproductstore.com/pvc-cut-and-curl-jacketing-w-ssl-3ft/
    Elbows, tees and fittings also available.
    Typically these are white, but can be custom ordered in a variety of colors (most typically the OSHA pipe identification color coding)
    Robbbbb
  • ChrisJ
    ChrisJ Member Posts: 17,519
    You can use fiberglass pipe insulation or you can use melamine pipe insulation.
    The price of the Melamine will make you cry.
    Robbbbb
    mattmia2 Member Posts: 17,478
    you could box it in after you insulate it.
