do you need insulation under a radiant slab
mikedo
mikedo Member Posts: 302
as it says in title do you need insulation under a radiant slab
  • Snowmelt
    Snowmelt Member Posts: 1,454
    Answer hell yea , otherwise you will be heating up dirt / sand or earth
    hot_rod Member Posts: 27,816
    If not some of your heat energy $$ goes down into the earth. How much and how quickly depends on the soil below moisture, conductivity, etc
    No amount can stop the energy movement, 2” seem to be the amount that most codes require
  • HomerJSmith
    HomerJSmith Member Posts: 2,794
    Heat energy travels in a straight line to what ever is coldest. Up, down, or sideways. Especially so if in bedded in concrete. Use high density foam board, not the bubble wrap stuff.
