steam condensate
please see following
pumps keep getting air locked-any thoughts
  • ScottSecor
    ScottSecor Member Posts: 1,055
    edited November 2022
    We've had issues with similar pumps when used as boiler feed pumps.   Any grit (rust, etc) will wreak havoc.
    Is there a real fine strainer on the inlet side of the pumps?
  • JUGHNE
    JUGHNE Member Posts: 11,634
    For simple sump lift pumps, (not really different than your steam Pedestal pumps), a 3/16 hole drilled in the discharge line just above the water line is recommended to avoid this. FWIW
