Small leak in flexible coupling on boiler
Shorelineleague
Member Posts: 1
I have a Dunkirk 095-200m boiler. There is currently a small leak coming from the flexible coupling between the boiler itself and the 2 inch pvc vent pipe. Is this as simple as getting a replacement coupling? See attached picture of the leaking coupling and a stock picture of the replacement. Any advice would be greatly appreciated!
That is a transition coupling from the Aluminum block and the pvc. Hopefully thats the issue and not the aluminum...
You will need to get the specific part from ECR/ Dunkirk as that one is rated for high temps and a simple Fernco is not.0 -
What kcobb said0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
