Pex-AL-Pex for between the joist radiant
axeyal
axeyal Member Posts: 8
edited November 2022 in Radiant Heating
I'm planning adding staple up underfloor radiant heat between the joists of the first floor of my house.
I have access to some leftover Pex-AL-Pex 1/2 inch tubing. Has anyone used Pex-AL-Pex to run the radiant loops between the joists?
How much more difficult is I compared to regular oxygen barrier pex?
I'm concerned it will bend and kink.
Thanks!
  • Paul Pollets
    Paul Pollets Member Posts: 3,672
    If it kinks, you'd have to cut out the kink and splice in a new piece. It's far easier to run 3/8" barrier pex within the plates, and avoid the hassles or wrestling 1/2" piping.
    axeyal
    hot_rod Member Posts: 27,816
    It can be done, but usually a two person job
    If you  are threading through holes drilled in joists, that is where you tend to kink it
    Do you have fittings for it?
    axeyal
  • axeyal
    Thanks hot_rod. I decided to go a different way since it is more difficult to work with compared to regular oxygen barrier pex.
