Pressure Test Painted vs UnPainted
Varus85
Varus85 Member Posts: 2
Why is there a 30x (3 vs 90) difference in the pressure test for painted vs unpainted Pipes? How does that make any sense? Is 90 only for freshly painted pipes?
  • GroundUp
    GroundUp Member Posts: 2,527
    What?
  • Varus85
    From the New York City Code: (3) Notwithstanding the above, all coded or wrapped pipe shall be pressure tested at a minimum of ninety psig. For testing, the piping shall be filled with air or an inert gas, and the source of pressure shall be isolated before the pressure readings are made. All test duration time periods are to be measured after stabilization of testing medium. Fresh water may be used as the test medium only where the required test pressure exceeds one hundred psig.
    Uncoded is three psig
  • PC7060
    PC7060 Member Posts: 1,844
    edited November 2022
    Perhaps due to that uncoated pipe can be visually inspected? But that would not cover pipes inside wall.
    Perhaps there is a increased opportunity for corrosion with coated pipes? That seems counter intuitive.
    Varus85
