What's this clunking noise in my gas DWH? Is it on it's way out? (Video)
Doing maintenance in a tenant's apartment and I noticed the WH making odd noises I've never heard before. Stopped when I turned off the burner. No leaking, but the tank is 2010. Time for it to go?
https://youtube.com/shorts/C_S3kK1NoGU?feature=share
  • As the tank fills with minerals the burner has to heat the sediment to heat the water, so that may be the percolation sound. Same happens to a tea kettle that fills with lime and hard water scale.
    Sounds more like someone banging with a mallet than perking! Ughh. The more I think about the more I want to replace it if I have time left between finishing the shower replacement and when the tenant returns from her trip. It's 12, the end can't be long, and better to do it not as an emergency.
    As always, the big problem isn't the work, it's getting the damn 40 gal tanks up and down from the 4th floor! My back has told me never again, and I believe it.
  • Hi, I agree with Hot Rod, that it's sediment. One approach would be to use Mag Erad to dissolve the scale. I'd only do this if you first checked the condition of the anode and found some metal left on it. Some gas controls have an adjustment for dialing down the size of the main burner, but your control isn't one of them. :/ If you do replace the heater, make sure it has a magnesium anode in it rather than aluminum. As aluminum dissolves, it produces lots of goo that falls to the bottom of the tank, encouraging noise. Magnesium doesn't do this.
    Yours, Larry
