Has anyone had this Federal Boiler Airscoop
Joseph_4
Joseph_4 Member Posts: 320
I have a customer who I observed myself after one turns boiler. in about 3 minutes i hear popping sounds that the water is flashing to steam and caused the prv to dump water consecutively. Its a new PrV and Expansion tank.. It happens really fast starting from cold start... but not all the time. I rebled all zones and had all zones working fine the last time i worked on it and shut boiler down with boiler switch. The Boiler is a Federal Boiler and It has a square box like air scoop. any ideas what the problem can be. here are some pics
thanks
Joe
    mattmia2 Member Posts: 18,048
    What happens to the pressure gauge as this is happening? What is the precharge in the expansion tank?
    HVACNUT Member Posts: 7,666
    Ahhh, memories. I haven't seen one of those in a long time.
    You replaced the extrol and relief valve but left the crusty auto vent?
    The pressure only rises when the burner is on? It's not a tankless coil leak?
    Is there an indirect water heater?
    Is the pressure reducing valve working?
