Automatic Vent Damper
Good morning gentleman,
I'm looking on adding a vent damper to my boiler, but I'm not sure if I have the correct item. My boiler is not a Burnham, but as per supplyhouse.com I can see that the damper is compatible with Burnham boilers that use similar Honeywell ignition modules like the one mine does. I was searching on supplyhouse.com and came up with the following one: https://www.supplyhouse.com/Burnham-8116323-6-Automatic-Vent-Damper-for-205-206-IN5-IN6-Boilers
I have the Honeywell S8610U installed on the boiler and I am worried that the Molex connector supplied with the vent damper is not compatible. Can anyone verify that the connector with work with the connector on the vent damper cable?
Thanks in advance for your help as always,
Pete
