part needed for Coleman gas furnace
zepfan
zepfan Member Posts: 467
I am trying to locate an igniter assembly for a very old (1981) coleman gas furnace. The part is a three rod assembly that has a has an spark rod, flame sensor, and separate ground rod. I called Coleman, and found that they are now owned by Johnson Controls. I was told that the part is obsolete. I didn't know if anyone knew of a place to buy parts for old furnaces. The ignition is a direct spark to ignition set up, no pilot tubing. Thanks to all.
    EdTheHeaterMan Member Posts: 12,506
    edited September 2022
    If you have a photo, and a model number of the part or the furnace model number. A number for the control that makes the spark might also help. But really, a 1981 furnace is now over 50 years old. The life expectancy of a furnace in 1981 was 17 to 26 years.. You have had double that in service from that furnace. I think it is time to send your furnace to its final resting place.
    Let us all take this time to have a moment of silence for this 1981 Coleman. You served us well Cole! :(
    EBEBRATT-Ed Member Posts: 20,481
    @zepfan
    You should probably think twice before putting $$ into that old beast.
    But, the pilot burners etc are usually a standard part made by the control manufacturers like Robert Shaw or Honeywell. Look at your gas control and that may give you a clue of where to look. But it could be an obsolete part if it is a standing pilot which it probably is
    You can probably get a conversion kit to install a new control and igniter assembly but it's probably not a DIY job and is probably not worth doing that
    zepfan
  • zepfan
    I was able to find the assembly on a coleman mobile home parts website. Apparently Colman continues to make furnaces for mobile homes, in which some use this same electrode assembly.
    mattmia2 Member Posts: 17,469
    Baso probably make something that would work too.
    Good luck. You should start putting your pennies into a piggy bank for installing a new furnace if you plan on living there for any considerable length of time.
  • zepfan
    It was not my furnace, it was a customer's. I would imagine that they know they are going to need a new furnace, but it had to be repaired in the inter rum
    I never heard of Inter rum. I am a Captain Morgan Man myself
