LPG connectors CGA510
This may be a bit of a strange question but are all CGA510 connectors basically the same and interchangeable?
I see some connectors with a solid brass male connector and I see others with an O-ring. Some are called POL and others just CGA510 but best I can tell POL is CGA510.
What's the deal?
What's the deal?
Can't answer that question, but the O-rings don't last very long on the type that uses O-rings to seal. I prefer the brass to brass connectors. I suspect them o-m ring type seal easier for HO's with less wrenching.Bob "hot rod" Rohr
Living the hydronic dream0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
