4" Sharkbite?
I had no idea they made them this large. This is for installation at a major manufacturing facility.
    mattmia2 Member Posts: 17,133
    I hope that is a drain.
    EdTheHeaterMan Member Posts: 12,425
    edited August 2022
    I did not know that they manufactured "Majors". I thought they were promoted from "Captain"
    Shows how much I know!
    But this is probably off topic
    CLamb
    or rf
    hot_rod Member Posts: 27,674
    I think it is a 4" Viega press fitting.
    GGrossPC7060
    EBEBRATT-Ed Member Posts: 20,347
    I agree with @hot_rod. looks like 4" P press to me. Probably worth over $200 by now haven't bought any in a few years and don't want to.
    GGross
    109A_5 Member Posts: 4,153
  • ScottSecor
    ScottSecor Member Posts: 1,042
    We use them all the time. I agree they are not cheap, but neither is the labor required for soldering a four inch copper tee (plus the solder, flux, acetylene, sand cloth, etc.)
  • That makes sense, but I thought those teeth made it non-removable.
  • ScottSecor
    @Alan (California Radiant) Forbes I assume your referring to the Viega Pro Press tee. Yes the shiny "grippers" can make it difficult to get a piece of tubing out of the fitting, but not impossible. Also, we are careful to remove any burrs on the end of the tubing.
    As I recall the 4" PP fit sloppy, and nothing grabs until you pinch it. Unless my memory is shot
  • pedmec
    pedmec Member Posts: 1,443
    I don't think its a Viega as they put a green dots on there fittings. Could be Apollo propress. this is all we do, its just to fast not to use and pretty much seals every time.
