Gas Valves Burnham Boiler IN12
Lanz
Lanz Member Posts: 3
I have a IN12 burnham steam heating boiler. I noticed that I have 2,  3/4 gas valves, what is the purpose/reasoning behind this ? My old boiler I had just one gas valve, same name and model.
    EBEBRATT-Ed Member Posts: 20,165
    must be two stage? post some pictures
    Lanz
  • Lanz
    Could be two stage or two valves for higher capacity. You could tell by looking at the wiring and wiring diagram
    Lanz
    mattmia2 Member Posts: 16,746
    Could it be something with smooth light off, the valves open at different speeds?
    Lanz
  • ChrisJ
    ChrisJ Member Posts: 17,374
    They have two unions on there.
    "That's ok, the manufacturer put them there making them magically different than if the installer does it".
    It is a listed assembly.
  • Lanz
    Thanks for the help!
