Need help fixing the leaky faucet handle
Not sure the brand, but as a general guide you usually have to;
Turn off the water for that handle
Pry off the little cap at the top center to get to a screw
Remove screw to pull off handle
Unscrew the bulging bit (not the part that's touching the sink, just the part above it
Then you can see what you have, send pic here or bring pic down to hardware store
Good idea to put drain plug in to stop any fumbled parts from falling into drain
Good idea to have small pail or rags handy when you turn off water supply.. sometimes they start dripping when you close them off - if theyve been untouched for a long time. Worst case there, is you might need a new shutoff valve.30+ yrs in telecom outside plant.
Currently in building maintenance.1
Water leaks out fro handle when turning water on. I think something inside the handle needs to be replaced, do you know the brand of this faucet? Thanks
