12# PRV Which brand actually works
It seems that the PRV on many boilers, does not make up water after a repair to the system. Is there a brand that is more reliable? The common "red" ones seem particularly bad.
    hot_rod Member Posts: 27,535
    Caleffi 573 Autofill. It can be easily serviced, cleaned, or cartridge replaced. It is a fast fill valve, always. No levers, bolts, anything to adjust. Sett it and forget it.
    STEVEusaPAkcoppmattmia2Steve Minnich
  • HomerJSmith
    HomerJSmith Member Posts: 2,782
    edited July 2022
    Caleffi autofill is the only valve that I use and it has a shut off knob on the bottom, too. I can set it with a screwdriver to the Xtank pressure easily. If I need a gauge, it has one too. A great product.
