all the preset 3/4" clip on aquastats seem to run 95-115, i need 135-145 kinda thang
archibald tuttle
Member Posts: 1,199
@HVACNUT thanks, I knew about the adjustables, e.g this strap on, because i'm trying to monitor return temps, but as a matter of expense and convenience where i don't need adjustment thought I would easily find a fixed temp fixed differential curved surface button style with like 135 cut in and 10 or 15 deg. fixed differential. but so far drilling empty holes. i've managed this kind of thing with ODR style relays with the temp sensor on the return that have an anti-condensing minimum temp set, but in this case i'm not looking for sliding scale temp based on outdoors, just when this adjunct call is signaled to stay just above condensing temps.
I am absolutely sure I could generically obtain a flat surface bimetal button in this range and make my own 'clip'. I don't know about those designed with the slight curve for pipe mounting, nevemind the clip question. so this could be a question of more familiarity with process/industrial/appliance style controls than hydronic heating controls.
Johnstone supply has a good selection of "snap discs". They will either be a F or L. Fan for fan, make on temperature rise. L for limit, which break on temperature rise. A hose clamp is a work around
I suppose you could file a piece of aluminum bar stock to get a flat- round adapter. The box stores sell short pieces of all shapes of aluminum.
One simple way is to use a hole saw the size of the tube. Drill through the piece of aluminum, then hack saw in half. Theres your adapter.Bob "hot rod" Rohr
Living the hydronic dream0 -
@hot_rod thanks. johnstone is good to plumb . . . sorry :-)
also found these senasys products which don't need to be modified, ready made for 1" pipe mount. They don't have the precise range I'm after but the make at 140, break at 150 option given the plue or minus 5 degrees is probably just fine and i can get em with 72" leads. it's 15 amp rated at 120.0
