Rheem 96v variable speed question
hank66
hank66 Member Posts: 3
Should I expect the airflow to be variable and self adjusting? In heating mode, seems to operate at a single speed only and it’s high. Looking to lower the fan speed. Using with an ecobee thermostat, configured with HVAC fan control and variable speed fan control.
    mattmia2 Member Posts: 18,044
    it looks like it is 2 stage. you need to either use a 2 stage t-stat or set up the controls to run 2 stage off a single stage t-stat. read the manual.
    Aluvaboy
