new oil furnace - new water problem
ejoseph
ejoseph Member Posts: 1
Hi & thank you for reading. Owned house about 30 yrs and never a problem. Added a new oil furnace. Since then have water leaking in to basement thru clean out door. Have white efflorescence stain on outside house on chimney. Installer says water is condensation caused by exhausted air (383 degrees) cooling before discharging chimney, turning to condensation/water and dripping back.
thoughts, suggestion is my installer taking me down the wrong path ?
THANK YOU !!!!!!!!!!!! Ed in Massachusetts
  • Jon_blaney
    Jon_blaney Member Posts: 329
    Furnace or boiler? What did you have before and what do you have know. Pictures?
  • Jon_blaney
    Is this an exterior chimney or is it all interior?
    EBEBRATT-Ed Member Posts: 19,310
    Did they install a chimney liner? Is this an exposed or interior chimney? Did they check the boiler/furnace BTU versus the size of the chimney
    mattmia2 Member Posts: 15,234
    Shouldn't the installer be fixing it if they put in a new furnace without a liner and it needed a liner to draft properly...
  • Solid_Fuel_Man
    Sounds like you need a liner, possibly an insulated liner especially if the chimney is exposed to the cold for more than a few feet.
