Can anyone verify if this air separator cap will work?
Timco
Timco Member Posts: 3,040
I have a B&G vent that needs a new cap / float. I cannot find a B&G branded unit but this Caleffi sure looks like it. Anyone know if this is indeed the right part? Thanks.
    mattmia2 Member Posts: 15,374
    edited January 2022
    @hot_rod is the one to ask about this. You can also try unscrewing that top cap and see if you can clean out whatever is keeping it from sealing.
    Timco
  • Timco
    I’m always reluctant to remove anything without the new part in hand. If it won’t seal back up things got worse. Now I can tighten the small cap and seal it up.
    HVACNUT
    hot_rod Member Posts: 26,476
    Save some $$ this should be all you need to replace. Most times they can be cleaned, occasionally an o-ring rips. Best to have the whole new assembly.
    SuperTech
  • Timco
    Ordered. Thanks!!
  • Timco
    tommay said:
    First just push down on the needle valve inside to flush it out in case there is just some crap caught up in there....a little drip isn't much of a problem as is screwing the cap down.
    It’s pouring water out if I loosen the cap. Replacement ordered.
