Smallest Oil-fired Hot-Water boiler out there?
Steamhead
Member Posts: 18,209
One of our customers wants to replace the down-fired W-M 2-68 that's heating his addition and indirect tank. No, it hasn't been plugging up, just thinks it's getting old. Haven't gotten the heat loss done yet, but the 2-68 still appears oversized for this job, hitting high limit frequently.
The smallest one I've found so far is the Burnham MPO-IQ84 and its Force clone that Ferguson sells. These fire at 0.60 GPH. Anyone know of anything smaller?
Consulting
Consulting
Biasi B-10/3
https://qhtinc.com/biasi-products/b-10/0 -
I wonder what burner is used. Maybe my file isn't up to date but it shows a .67 input with the Riello F3. Carlin 2 stage?DJD775 said:Biasi B-10/3 https://qhtinc.com/biasi-products/b-10/0 -
Peerless and Crown are .60 input. Peerless has condensing oil that fires.50 but I am sure you want no part of that0
Yeah the Biasi says .51 firing rate, Carlin, Riello or Beckett0
I wonder what burner is used. Maybe my file isn't up to date but it shows a .67 input with the Riello F3. Carlin 2 stage?HVACNUT said:DJD775 said:Biasi B-10/3
I see 0.67 input in the Riello setup manual too. I believe at one point they were shipping with 0.40 nozzles but they could have switched back to 0.50. How is the MPO 0.60 input with a 0.50 nozzle @ 180 psi and the Biasi Is the 0.67 input with the same setup? Either way these are about as small as you are going to get for oil boilers.0 -
I don't think you can go wrong with an EK boiler. The Trio Pure Pro can be fired with an F3 Riello .55 60A nozzle. 75,000 Net BTUs.0
