Cast Ray Radiator Question
Hi All, begging for help.
I am installing an 8 section Cast Ray and the plumber did not center the stub outs on the wall as I asked. Because of this, I am trying to frame out the radiator as far right as I can while still leaving enough room for the left pipe to connect to the radiator. Plumber says he cannot tell me how much room he will need until the radiator is put in, which is in turn holding up entire job. Is anyone able to tell me about how much room will be needed to connect the left pipe to the radiator? Is it more than 3 inches?
The radiator is at this link > https://www.pexuniverse.com/uploads/literature/ocs-ray-specs.pdf
and my room currently looks like this
