Relay making chattering noise
percilla96
percilla96 Member Posts: 2
About two weeks ago we noticed the blower relay on our furnace started chattering, today we went and bought a new relay for it, installed it no issues runs fine, until tonight when the brand new relay chattered. Is there something else wrong? The furnace is a Honeywell and it's from 1990 if that helps.
    EBEBRATT-Ed Member Posts: 20,482
    Could be a loose wire, weak transformer or any one of a number of things. Hard to tell. A few pictures may or may not help.
    You need someone with an electrical test meter to troubleshoot this
  • percilla96
    Actually figured out the Gas Valve making the noise, this is a new noise. So we will be having a person out to look at it.
    mattmia2 Member Posts: 17,475
    Typically it is a loose wire somewhere.
  • HomerJSmith
    HomerJSmith Member Posts: 2,794
    Check the voltage at the coil connection to the relay.
