One pipe steam radiator vent keeps failing
Alex23
Member Posts: 1
We have a cast iron radiator with grill in the bathroom, kind of like this one https://castironradiatorsusa.com/products/cast-iron-radiator-w-grill-20-h-x-13-1-2-l-x-5-w-6-sections
The problem is that the vents keep failing. I've went through several by now. They start spitting water. Sometimes it's downright trickling out! The latest one we had fail is Vent-Rite V/T1 https://www.hardwarestore.com/brands/167254-vent-rite-v-t1-radiator-vent.html?ps=190
The radiator also makes weird gurgling sounds quite a lot. Is it possible that there is something wrong with the radiator and it messes up any vent we put in there in the matter of weeks?
Our boiler cut in is set at 1psi. Pitch is hard to determine in that space, but it shouldn't be an issue or not a big one.
Thank you in advance for any ideas!
- 87.8K THE MAIN WALL
- 130 Chimneys & Flues
