Burner whining...
loudburner
Member Posts: 2
My 24 y/o Riello started making this noise... see youtube link to hear below. it's been regularly serviced since new. next service date is in 3 days.
https://youtube.com/shorts/9MUeH3FHofU?feature=share
assume it's a bad bearing or something, ok to wait the 3 days? or push the service company to get someone down here asap?
UPDATE: tech listened to video, they stated ok to wait til Friday.. i have that in writing should it come back to haunt me....:)
thanks
thanks
Thanks much. It's been working flawlessly since 1997, that and the Weill Mclain boiler. other than replacing a valve here/there and a circulation pump i have been pleased with the unit. the burner does sound like a jet engine, something the tech warned us about when installing l..lolBig Ed_4 said:Yes the greased bearings seem to dry out about twenty years , no danger except for the noise .. You can pop off the pump , cup the motor with your hand to hold in some oil and turn the burner on and the noise would go away .. Buys you a few years ...0
