Boiler tube cleaning help
conrajetken
Member Posts: 10
I have a Burnham RSA125 residential steel boiler. It has 1-1/2” tubes. Can anyone tell me what type and size brush I need to properly clean the tubes and if there is an online source for the correct brush, thank you.
@conrajetken
Supply House.com has cleaning brushes. Tubes are sometimes measured by the od. I would measure the id and call them to get the right brush0 -
That is a fire-tube boiler, right? Is it gas- or oil-fired? You want brushes that are slightly larger in diameter than the i.d. of the tubes. You just want to clean the tubes, not abrade them. If gas-fired, once every couple of years should suffice.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
