Hydronic ceiling application.
cnmdesign
Member Posts: 103
Running 1/2" Pex Al Pex 8" oc and having trouble with coaling on the u-turn.
How much is too much? Is any too much?
I'm 100' in, hate to have to take it down.
Using Johns application.
https://www.pmmag.com/articles/96488-radiant-ceilings-are-a-great-option-in-many-systems)
Combat Veteran owned, Final Salute LLC on FaceBook & Twitter.
www.afinalsalute.com
Are you using an uncoilrer? That tube needs to rotate as you make the 180 bendsBob "hot rod" Rohr
Living the hydronic dream0
