Grundfos Alpha2 and Webstone isolation flange
Le John
Le John Member Posts: 250
I want to replace a Grundfos 1558 with an Alpha 2. When I line up the bolts it looks like the box for the conduit will not fit with the isolation valve in the open position. Has anyone experienced this? Before I tried it I figured I would ask. Doesn’t appear it’s going to fit.
A safe and Happy New Year to all.
  • Daveinscranton
    Daveinscranton Member Posts: 148
    Take take off the valve handle.  Use a 4” or 6” adjustable wrench.  Leave it off and use the wrench as a handle.  Or trim the valve handle with a hack saw.
    Best wishes.
    Alan (California Radiant) Forbes Member Posts: 4,747
    edited December 2021
    Sometimes you have to modify the handle to make it fit. We remove the yellow rubber cover from the handle, cut the handle shorter with an abrasive saw and then put the rubber cover back on.
    Or just remove the handle and leave it hanging from a pipe for it to be used when needed.
    You should also be able to rotate the flange 90 degrees and have the pump facing to the right.
    EBEBRATT-Ed Member Posts: 20,292
    I am not a Grundfos expert but can't you turn the motor 90 deg like other pumps?
    Derheatmeister
    hot_rod Member Posts: 27,589
    Yes but the digital display would be sideways
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Rotate head of circ and handles of webstone until it works..
    Have fun wiring it :D
  • GW
    GW Member Posts: 5,184
    What everyone else said
    Or go back to the vendor and ask
    for a “rotated flange” alpha
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
  • Le John
    @Derheatmeister - What do you mean have fun wiring it? I'm wiring this to a Taco Zone Valve Controller? Is it easier to get a Taco VR1816 with universal Flange?
  • Le John
    Sometimes you gotta make it fit! Appreciate all the comments - I’m not in the trades but love this site. My wife says I should have been in the trades instead of information technology.
  • HomerJSmith
    HomerJSmith Member Posts: 2,791
    Do you think that the pump may just suck air into the sys thru the vertical air eliminator?
    Depends on where the expansion tank is connected
