Split Flanges/Escutcheons - how to measure?
Joejoyce
Member Posts: 1
ok, I am baffled about how to accurately measure my radiator pipes (steel or iron) and buy the correct split flanges. Two parts to this question:
1. I measured my larger pipes and they are 1 3/4'; the split flange that fit stated it was 1 1/4". So those are complete.
2. Smaller pipes measure 1 1/4" - but I can't find the right size flange to fit. If I use the proportions in #1 above, the size would be 3/4" flange, but that is too small. One online plumbing place suggests 1 5/8" flange but that seems counter intuitive to the proportions in #1.
Any ideas on what size I should use to get #2 properly fitted?
Thanks, Joe Boston MA
It'd be a escutcheon for 1 inch pipe.
SCH 40 Pipe-1 1 in pipe size 1.315 in ODTrying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
Yes, it is kinda of confusing. Flanges come in two flavors, copper size and Iron Pipe Size. IPS fits Iron pipe.
1" iron pipe has an overall dimension 1-1/4". 1" copper pipe has an overall dimension of 1-1/8". 1-1/2" ABS has an overall dimension of 2". It has to do with wall dimensions.
Ordering 1" IPS flange will have a 1-1/4" hole.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 5.7K Gas Heating
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 6.3K Radiant Heating
- 392 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 46 Industry Classes
- 49 Job Opportunities
