Taco 4 way mixing valve alternatives
snoop
Member Posts: 10
Due to long lead times, I am looking for alternates to the taco 4 way mixing valve for a set point of 85F. I have a boiler putting out 180F degrees heating high temp zones as well.
I have found this very simple one but I am unsure if it can work as a set point. I think it could ultimately let in water hotter than 85f.
https://www.supplyhouse.com/Tekmar-720-3-4-Brass-4-Way-Mixing-Valve-4869000-p
Do you require a 4 way or could you use a 3 way ?
https://www.supplyhouse.com/Taco-I100T3S-1-1-3-Way-Setpoint-I-Series-Mixing-Valve-w-SensorYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Hi where are you located? I can have an account manager do a search to see where it was sold, and if someone has it sitting on there shelf.
try calling 401-942-8000, and ask for tech support.
Let me know how you make out.Joe Mattiello
Taco Comfort Solutions0
