where should I add main vents to steam pipe
PatB
PatB Member Posts: 43
Hello, all,
Please help me...
It seems there are no main vents on my steam pipes. Could you please help tell me where I should add the main vents. The guess the pipe are about 35 to 40 feet.
many thanks!
Pat
  • neilc
    neilc Member Posts: 3,196
    nope, you showed em to us,
    the middle couple pictures,
    the main goes out to the loop end, and extends back to the boiler, where your vents are,
    now, are they large enough? and working?
    one pipe rads upstairs?
    other than the vent question, what are you solving ? what issues?
    known to beat dead horses
  • PatB
    thanks, do you mean the vents on top of the vertical pipes? Are they main vents?
    The reason I am asking is that it take long time for the heat to get to the farthest radiator? thanks
  • neilc
    Yes, those are your main vents, looks like 3 of them, each on a different extension/return,
    are there more returns behind those vents? I see more verticals,
    can you tell which vent is servicing the slow rads?
    post a picture of each end of one of the slow radiators
  • PatB
    thanks, I will get more pictures tomorrow.
  • PatB
    The system only has two main vents as you suggested. Pipes slit into two parts: one to the backroom which send steams to the radiators to the back of house (the systems heat two floors, first and third), the other one goes to the front of the house. The far ends are to the radiators of the front of the house.
    thanks
  • PatB
    the first picture is the pipe goes to the first floor radiator which is the slowest to get heat.
  • JUGHNE
    JUGHNE Member Posts: 11,603
    I see 3 main vents. Also 2 boilers.
    Pictures of the boilers piping floor to ceiling would help.
  • PatB
    one boiler works fine, there is no complaint.
    The issue is with the boiler with two main vents. will get more pictures.
    By the way, could it be the main vent clogged? if so, how to clean the main vent? thanks
  • neilc
    thanks
    there is a third vent between the 2 you show, and know,
    that little silver bullett to the right, hiding behind the vertical pipe,
    and give us a clue, the boiler on the left, or right?
    I'm guessing left, and your mains are on this side of the center beam,
    a picture of both boilers, floor to ceiling,
    and then of the boiler in question, floor to ceiling,
    showing the pipes, floor to ceiling,
    clogged vents, try soaking, boiling them in vinegar,
    easier to replace them,
    but, measure those main lengths, out to the loop and back to the vents,
    post that and main diameter size,
    you're going to want larger venting
  • PatB
    neilc said:
    thanks
    thanks, yes, the boiler on the left is the one concerned here. I took some pictures, may clear enough to you. I will do more tomorrow. here are what I have.
    basically, there are only two main vents for the left boiler, the silver vent is for the right boiler.
    I didn't measure the pipes, will do tomorrow.
    dennis53
  • neilc
    you've posted a lot of pictures,
    post the one you're referring to again,
    and what problem are we solving for?
    one cold rad?
    or several off the same main?
    maybe the rad needs a new or different vent
