Replacing radiator air vents
mjgordon
Member Posts: 16
I have three radiator air vents that are at least 16 years old and won't stop venting when they come up to temperature. 2 are maid-o-mist no.4 and 1 is a Gorton D. Since I've had good luck in they past with Gorton and Hoffman but not MoM, I thought of replacing the MoM4 with Hoffman 40 and the Gorton D with another Gorton D. I saw the H40 had slightly higher venting rate than the MoM4. Is this a good course to take? Other choices or recommendations?
It's unusual to find a Gorton or M-o-M #D vent on anything but a radiator of 100 Square feet or so. First thing I'd do is check and likely upgrade your main vents.
Consulting0 -
Steamhead, thanks. Two 2" mains of about 20' each that are each vented by a Gorton #1 vent. The radiator with the Gorton D is about 32 sqft EDR, and I always thought it weird but didn't want to mess with whatever balance was achieved years ago.0
- 128 Chimneys & Flues
