Taco I-series questions
Mosherd1
Member Posts: 77
First question, when using two Taco iseries valves and using two outdoor air sensors, can I run one 18-5 tstat wire and use 2 wires in it for each sensor, or do I have to run two separate cables?
Second question, does the iseries require a 10 temperature differential from the supply temp. vs. the mixed temp like a conventional thermostatic mixing valve or since it’s computer controlled it doesn’t matter?
Yes, you can use the the multiple wire stat wire and run two sensors. Use one "outdoor sensor box" for one
i-valve because the thermistor is molded into the enclosure and a separate sensor for the other i-valve in the same outdoor box.
You can make the boiler temp match the mix temp, it is a "ball" style valve and will go to wide open if needed.
Dave H.Dave Holdorf
Taco, Inc
1 -
Use the smallest size I Valve where the CV closely matches your flow requirement also . This smaller valve will reach the target temperature fasterYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330
- 120 Geothermal
