Cast iron radiators for wall mounting
HenrikW
Member Posts: 8
To the HH Community - I've been looking to replace an old cast iron rad on my basement wall for a number of years as it's been out of service due to a crack which we had tried to weld unsuccessfully. The thing is, this unit has no feet / looks specifically made to be wall mounted. Are there any manufacturers left who make cast rads for steam without feet anymore? All I was able to find are welded steel ones but I like the more durable heating you get from cast iron.
Here's a pic of the unit. I believe it's an ARCO Peerless unit, from 3 joined sections. I'd love to find an exact replacement.
Thank you,
Henrik
Thank you,
Henrik
I was just going to post an update - found that OSC actually offers the standard 4 or 6 column tube cast iron rad as a wall mounted version without feet and with compatible mounting brackets! (https://ocsind.com/products/wall-hung/). Hudson Reed cast iron rads I saw were all for hydronic systems and not compatible with steam.0
@HenrikW , where are you located?All Steamed Up, Inc.
Consulting0 -
That's a pretty one.kcopp said:Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.1 -
Have you tried to repair the radiator with a metal repair epoxy? If not, you might drain it and try a repair where a weld repair was tried. The welding may have damaged this radiator beyond repair but it’d be worth a try. JB Weld works well.0
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
