Question on T-stat wiring on a Weil McLain Steam Boiler
Chris_108
Member Posts: 27
Hi guys,
I am a bit confused on my basic 2 wire steam heat T-stat wiring.... At the T-stat I have 2 wires: 1 going to R terminal and 2nd wire going to R/RC (jumper between R & RC)
so at the transformer on my Weil McLain Peg steam boiler the wires connect to terminals other then W & R. The W wire connects to Y terminal and the R wire connects to the G terminal. I always thought they should correspond the the same terminals at both ends? Am I mistaken?
Reason I am asking is I would like to replace my basic honeywell basic programable T-stat with a Ecobee 3 lite that I bought over a year ago but never hooked it up.
I realize Ideally I need a common wire which I don't think I have so I will need to look at the various options available but before I start to mess with this I want to make sure my existing wiring is ok and to be clear everything currently works as it should but was just surprised to not see the W and R terminal utilized on the transformer...
Any help is greatly appreciated...
thx in advance,
Chris
thx in advance,
Chris
Can you post some pics of what you have, and the wiring diagram?
Should be R and W at the thermostat, and R and G at the fan center control but Y could also be used in the circuit.0
