Vitodens Air Vent O-Ring Question
Beaver33
Beaver33 Member Posts: 24
My Vitodens 100W WB1B has a leak at the O-ring at the base of the Automatic Air Vent (Part No. 7819 971)? The air vent itself is fine.
I would like to purchase a replacement O-ring. Does anyone know its specifications/material?
Where can replacements be obtained?
    hot_rod Member Posts: 26,597
    if you can remove it, take it to an auto parts store, they have many sizes US and metric. Same with hydraulic repair shops
    Or try to order it through a Viessmann dealer
    Its probably a straight thread that uses the ring as the seal
    mattmia2 Member Posts: 15,610
    if you measure it i'm sure you can find it at theoringstore.com or a couple others.
