Help
wbenner
wbenner Member Posts: 1
I have an old Trianco Model DBC-100 boiler and I believe that it has developed a leak in the combustion chamber. Can that be fixed
  • STEVEusaPA
    Why do you think that?
  • If it's leaking from the heat exchanger, it's dead and can't be repaired. Trianco was purchased by Laars and they don't support the old equipment.
    Time for a new boiler.
    I don't recognize that model number. Is it a combi (domestic hot water and heating) unit?
    HVACNUT Member Posts: 7,355
    That's a vertical tube steel dry base boiler. Time for an upgrade to a cast iron 3 pass or a System 2000.
