question on cold water inlet on steam boiler
bennythepitbull
Member Posts: 37
13,14 or 20 would be better choices. Not12 too close to the water line0
I feel like 12, being the termination of the system return, is fine.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
thanks funny did not see the second one till today so you say the one between 21 and 200
The number is used to describe a specific fitting. The number 4 appears multiple times, it is an elbow. The 12 is a tee.0
Then maybe @JohnNY & I are both right. I wouldn't put it in the Hartford loop tee. you will get water hammer.
@bennythepitbull
21, 20,14 are good You don't want to put cold city water directly into the boiler. You want the cold make up water to mix with the returning warm condensate to warm it up1 -
just to be clear I'm referring to the bottom 12, I missed the fact that there was 2 12's, and I am aware its pointing out a part just did not see the top 12 --
would anything be wrong with number 22 the back side of the tee for a cold water inlet, or is the bottom 12 better then 22
again thanks all
- 87.5K THE MAIN WALL
- 119 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
