Kick Space Heater on Radiant Loop
I have a Quiet One 2000 Kick Space Heater that is connected via scoop T-s to a hot water baseboard loop. I would like to know if it can be relocated into a radiant loop zone, and if so, would I use scoop T's, place it in series or create a separate small loop from the radiant loop pump just for the kick space heater?  Thank you
Dave
    hot_rod Member Posts: 27,818
    What temperature is that radiant loop running? What does the output chart show for that temperature?
    If it is a 1/2 loop, you may not be able to grab much heat off it.
    EBEBRATT-Ed Member Posts: 20,469
    It likely will not produce enough heat off a radiant loop
