Main Vent Advice
fxrgrunt
Member Posts: 157
Last year with much advice from you fine forum members I got my main vents set up. First picture with Gorton 2 and Hoffman 75 is on a 66ft 2 inch line. Second picture is 3 MoM 1s on a 47ft 2 inch line. 1/2 pipe used to make antlers. I got in a second Gorton 2 today with will go on 66ft line and I will add the Hoffman 75 to the 3 MoMs.
Now for the point. If you look at the pictures you will see the existing piping that I plugged into was bushed down from the T to what I believe is 1/4 inch which is what I hooked my antlers to. I imagine that the 1/4 pipe will actually be holding back the 2 Gortons max flow as well as the other lines max flow and I should probably remove those reducer bushings and put in a 3/4 or 1/2 bushing in there? Am I correct here? Thanks.
If the bushing gets removed, I probably will put a nipple, then a 45 with a few inch long pipe, then another 45 before doing the vents if that all makes sense. Once again, just curious on the 1/4 pipe choking the air flow for now?0
Makes sense. I think after this upcoming heating season I will remove the bushings and maybe pipe it all to 3/4" to future proof it. I don't think I want to risk stripping or cracking anything right before heating season starts.JUGHNE said:At one time, I did crunch the numbers for a G2. 1/4" ips would do only 1 G2 adequately.
IIRC, 3/4" will do 4 G2's.
But it is only 2" long, of 1/4"....very short bottle neck. But still will slow the venting down. IMO0 -
I just did something like this to my own system a few weeks ago. Decades ago someone put a 1/4" bushing into the 1/2" outlet. I went to remove the bushing and it basically disintegrated, leaving most of itself fused into the outlet.
Luckily I am the proud owner of a 1/2" NPT tap. Unluckily the 1/2" outlet was too close to the ceiling to get a drill up there to drill out the remaining bits of the bushing. Luckily I am also the owner of a variety of large pipe wrenches and was able to disconnect the return from the boiler--I was hoping to give the fitting an eighth of a turn so I could fit the drill onto it. Unluckily, even with a good four feet of cheater pipe on my biggest wrench the original pipes weren't going anywhere.
I tried several other Majicks to clear the 1/2" outlet. I pinged at the bits of bushing with a cold chisel, hoping to chip it out of there. A keyhole hacksaw would not fit, but a small sharp file seemed to cut into the old iron--at risk of dropping the thing into my wet return.
The Wife Acceptance Factor was plummeting.
Luckily I realized I could put a jack under the wet return (that I hadn't been able to turn) and disconnect the main from the joist. Then I slowly lowered the jack until the main dropped enough (less than an inch!) to where I could drill out the remains of the bushing. THEN I could finally use the tap to clear the remaining junk out of the original 1/2" threads in the outlet.
Once I thought of lowering the main it was about a 30 minute job. It just required a whole other set of tools than I ever thought of when I started out.1 -
Hmm I don't see any 1/4" there. It looks to me that there is an existing 1x 1/2 bushing with a 1/2 nipple to a 1/2 x 3/4 coupling to a 3/4x1/2 bushing to a 1/2 close to 1/2 90 and so on. someone took the long way around but I don't see any restrictions.
1
- 125 Chimneys & Flues
