Bleed Valve Recommendations
LmAcres
Hi
I'm looking to replace the bleed valves on my old convectors (1941). Currently the valves are mounted through the face of the steel cover and connect to the convector via copper tubing. They've been painted over and gummed up through the years and since I'm refinishing the covers I wanted to get new valves. I can't find identical replacements, so I'm wondering if this style is even made anymore, or if I should remove the tubing and install new valves directly into the top of the convector? Seeing as the cover once installed would prevent access to the new valves, would you recommend automatic valves? Or are manual the way to go and remove the cover as needed (if needed).
Looking at their other post it is a flare fitting. The knob on the outside and the outlet on the inside of the cabinet seems like a bad idea.
Is this a private home? I was thinking of a recent post where someone posted about a remote bleeder valve that was in an apartment complex and I am sure the tenants wouldn't care about a leaking auto air vent. You could probably find a way to adapt the NPT of an ordinary coin key vent to flare and mount it through the cabinet.1
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
