Hoffman 70A
delcrossv
delcrossv Member Posts: 2,204
How does the 70A compare to the 40- faster, slower? (not listed in the guide to vents)
It's twice the price, so I'd like some guidance before I get some.
Thanks!
    Steamhead Member Posts: 18,714
    Slightly slower. ISTR it's more expensive because it is built to military specs.
    Consulting
    delcrossv
  • dopey27177
    dopey27177 Member Posts: 916
    The difference between the #40 and 70a valve is the operating pressure.
    The 70a is good to 15 psi max and the 40 is good to to 10 psi max.
    In a normal operating system in lower pressure applications such as systems that operate at pressures under 5 psig I would certainly use the #40 vent valve. There is no difference in the air discharge rate that would be meaningful.
    Jake
    delcrossv
