Weird cast iron failure
delcrossv
Had a wall stain on the basement of my MIL's building. Opened up the wall and the 2" cast stack had a vertical (longitudinal) split on one section Hub to the next section's hub. It's not like it was rotted, a lot of metal there, it's like the seam split like opening a zipper. Went in in 1912.
No room to put in new hub cast without opening up a lot of wall in the apartment above, so I'm gonna use either no hub or plastic with slip compression (Fasco) fittings.
Anyone else see a seam split like this? It's a new one for me.
The offending stack section:
Easy fix with slip connectors and a 4' length of 2" service weight CI.
Just a little drywall , mud and paint left to do.
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
Possibly, but I know cast is code here (Chicago) and I'd have to check for plastic. Also I want to make sure the next person to replace it ISN'T me.mattmia2 said:You could have used pvc as well unless there is some code issue that prohibits pvc in that particular structure
Splitting of the cast iron occurred on all 4” lines servicing bathtubs in my 1928 home. I’ve surmised it was due to the repeated hearing cooling cycles. Funny thing is cracks all occurred on top of pipes.I’ve replaced al CI in the house with exception of a vertical line that services a toilets. Scoped the pipe a few years ago during renovations and it looked good. Maybe because only servicing cold water. That same line had 1/2” wide crack 6’ long on horizontal in basement after the 2” CI servicing the tub was connected.0
- 52 Job Opportunities
