Draft Much?
JakeCK
JakeCK Member Posts: 1,502
To those who suggested it wasn't worth the coin to install an automatic vent damper this is how much my flu sucks:
https://youtu.be/j38eqlJOOs4
Ya'll can't tell me I won't recoup the couple bucks I spent on parts and the value of my saturday afternoon installing it. I also replaced the clean out door too. Now on to replace my 14yr old hot water tank.
  • ChrisJ
    ChrisJ Member Posts: 17,391
    edited September 2021
    Try it when it's 0F outside and the basement is warm and the flue is hot. If it's warm outside (40s-50s) then you haven't seen anything yet.
    I know my 30' 6" B vent drafts really good but I also don't know how much it actually would cost if left wide open.
    Also, fresh air is beneficial sometimes.
    But, I do use an automatic damper.
    JakeCK
  • Robert_25
    Robert_25 Member Posts: 571
    My house has a 35' chimney up through the house with an 8"x12" flue. Even with the baro wide open it will sometimes exceed -0.05 "WC.
    JakeCK
  • ChrisJ
    If you're seeing excess draft using the next size up damper, or even multiple dampers isn't unheard of.
  • JakeCK
    ChrisJ said:
    Try it when it's 0F outside and the basement is warm and the flue is hot. If it's warm outside (40s-50s) then you haven't seen anything yet. I know my 30' 6" B vent drafts really good but I also don't know how much it actually would cost if left wide open. Also, fresh air is beneficial sometimes. But, I do use an automatic damper.
    Oh I bet. I was just curious this morning since the boiler had fired not that long before. And this house is approaching a hundred years old, it gets plenty of fresh air. I just wish I could leave the basement door closed that would help tremendously, but my cats need access. :/
    Steamhead Member Posts: 18,507
    Better keep the cleanout closed, or the chimney will pull those cats up to the roof.
    I'd love to put a draft gauge on that, just to put some numbers on it............
    Consulting
    JakeCK
