Steady green light
DonMiguel
Member Posts: 1
I have 80% a quest furnace And it's not given me any codes from the control board It's just a steady green light Just trying to see what do I need to do to to get this unit up and running because these people have no heat
Thermostat calling for heat for starters.
If you have power to the board (120) volt and the thermostat R-W is calling and the door switch is closed it should start. Trace the wiring, check for power look at the wiring diagram.Maybe a bad board0 -
or bad t-stat wiring or dead batteries or a hundred other things. start with jumpering r-w to figure out if it is the t-stat or the furnace.EBEBRATT-Ed said:Thermostat calling for heat for starters.
If you have power to the board (120) volt and the thermostat R-W is calling and the door switch is closed it should start. Trace the wiring, check for power look at the wiring diagram.Maybe a bad board1
- 120 Geothermal
- 394 Solar
