Please help - System 2000 issue
Drifter
Drifter Member Posts: 3
Hello to all. New to the forum.
I am having issues with my EK System 2000. During a call for hot water the burner comes on and runs for approximately 60 seconds, and then shuts off, restarting on its own in about 8-10 minutes, only to again shut off about a minute later. The manager eventually locks out and 140 temp led flashes. I replaced the nozzle and electrodes, and changed the oil filter.
Any help or suggestions would be greatly appreciated.
    EBEBRATT-Ed Member Posts: 20,482
    Do you have a company in your area that services EKs? (not all do) Post your location.
    EK also hangs out here you will probably get a reply from them
  • Drifter
    I do, and they are good. I just don't want to call if it is a simple fix.
  • STEVEusaPA
    It’s nothing you can fix yourself. You might as well make the call.
  • Roger
    Roger Member Posts: 482
    Thank you, @Drifter . It's great to hear that you're up and running, and that you have solid heating pros that helped you get the job done!
    President
    Energy Kinetics, Inc.
