How to find BTU rating for 1950's Arcoliner
David_Dubois613
Member Posts: 1
Hi folks. I'm putting in a flue liner and need the BTUs for my Arcoliner model 0 155T, Series 2BT J3. Any ideas about either where to find it, or how to estimate it? Thanks!
What @STEVEusaPA said0
It's in here. The T in your boiler's model number (155T) probably means it has a tankless domestic hot water coil:
https://heatinghelp.com/assets/documents/182.pdf
There were a couple different versions and the rating is different for each. The "wet base" version has the return connection at the very bottom of the boiler, while on the "dry-base" version it is maybe a foot or so above the bottom. If you're not sure take some pics and post them.All Steamed Up, Inc.
Consulting0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
