Air Vent on Steam Radiator Won't Stop Hissing
ColdNights
About two days ago (nearing the end of our heating season), the air vent on my main steam radiator started hissing without regulation, meaning it just keeps going when steam is flowing. I can't visibly "see" steam coming out, but I can feel and hear it.
I imagine this is a straightforward problem as it just started, but I couldn't find a resolution on this page. I'm not sure if it means it just needs to be replaced, but thought I would ask before testing random amateur ideas out there.
Any and all advice is greatly appreciated!
I also checked and the boiler is at proper psi with and the sight glass looks as expected0
How many ounces is your pressure?—NBC0
My guess is the vent just failed. See if you can replace it with an identical model vent.
and a quick picture of the boiler, gage, Ptrol, and pigtail
is the gage after the pigtail, with the Ptrol?
or are they separate?known to beat dead horses0 -
Thanks! It is at/below 2 psi.0
Is that pressure measured on the 0-30 psi gauge?
It may not be accurate at the lower pressures needed for these systems. Best would be a 0-3 psi gauge, on a tee with the pressuretrol, and the original gauge.—NBC0 -
I have the same problem. I’m a heating professional and can’t figure it out. Only one radiator is non stop venting. Replace the air vent with two new ones of the same kind. Maid-o-mist and still venting non stop. Pressures under 2psi.
